Why are there so many types of converters?
Why does LabVIEW have dozens of converters?  Why can't we have a universal converter that you just wire up and it automagically converts the gozinta to the gozoutta?  Well, OK that's asking too much.  But I've got a good start on it.  This XNode (as it's title implies) will convert a string into practically anything.  It adapts to whatever is wired to the output.  (Also, depending on what you've hooked up, there can be an optional "Format" and/or a "Delimiter" input.  But usually the defaults are fine and you don't need to wire these.)
  • Numeric (all representations)
  • Floating point with Units
  • Enum
  • Boolean
  • String (just passes through)
  • Path
  • Array (choice of typecast or convert from spreadsheet string)
  • Cluster (choice of JSON or XML input)
  • TimeStamp
It even handles units:
Message 1 of 9
(3,046 Views)
@paul_cardinale wrote:
Why does LabVIEW have dozens of converters?  Why can't we have a universal converter that you just wire up and it automagically converts the gozinta to the gozoutta?:
This old (denied) idea would have dealt with Godzilla instead. 😄
Thanks, I'll have a look at your thing!
Message 2 of 9
(3,023 Views)
I think "Type Cast" pretty much does that.
But I am sure there are some caveats, so use it with caution.
https://zone.ni.com/reference/en-XX/help/371361R-01/glang/type_cast/
BTW: There are so many converters because there are so many data types and some of us have an "aversion to coercion dots". When I was starting out my mentor called them "loser dots" or "lazy dots".
I forgot about the newer "Coerce To Type Function"
Similar to Type Cast but works better for numbers.
https://zone.ni.com/reference/en-XX/help/371361R-01/glang/coerce_to_type/
=== Engineer Ambiguously ===
Message 3 of 9
(3,004 Views)
This is my first attempt at using an Xnode(?) vi?
I unzipped everything but opening the top level VI opens it in an empty project and placing it on the block diagram only places an empty vi.
Message 4 of 9
(2,961 Views)
Same here. Please include significantly better instructions on how to use all this.
Message 5 of 9
(2,942 Views)
Probably a missing dependency.  I'll submit a fixed version (in a bit,  very busy right now).
Message 6 of 9
(2,928 Views)
The previous version actually works with LV 2018 (which is what I built it with).  But with later versions, one of LV's enums changed, and since I have an overactive aversion to 'Default' cases, there was a case structure that broke.  Here is the fixed version.  Works with LV 2018, 2019, 2020 (of course it you're using 2019 or 2020, you'll get a faster load if you first mass compile).
Message 7 of 9
(2,917 Views)
Hi Paul,
Could you please post in LV2017 version.
Message 8 of 9
(2,777 Views)
@gkrn wrote:
Hi Paul,
Here
Message 9 of 9
(2,766 Views)
