11-14-2010 10:10 PM
In the attached VI, the "bounds" of the graph are far too large. How do I shrink the "bounds" back to a reasonable size (that property is not writeable)?
This problem developed when I was changing the "plot area bounds" with a property node in order to move the graph with respect to other FP ojects. How should I understand the difference between "bounds" and "plot area bounds"? What is the proper way to change the position of a graph using code?
Allan
11-15-2010 11:47 AM
Allan,
This is a good question. Programmatically this is not possible and will have to be done manually as covered in this KB. You can change things like the text size and Plot Area:size to change the height but most of these are manually set.
Hope this helps!
