Why Labview.exe error when exit simple-state machine?
I recently added the reset to default. I thought maybe that would reset whatever error is occuring. But apparently it doesn't help... =0/
Message 11 of 16
(1,187 Views)
OKAY! I have narrowed it down to this simple code. It is the skeleton of the simple-state machine. Can you tell what is wrong with it?
Message 12 of 16
(1,187 Views)
Hi Lauren,
Your simple skeleton runs perfectly in both LV6.1 and LV7.0.
I have four print outs, one for each run.
If you are having trouble with this VI, it seems the only thing left to suspect is the printer.
Try turning off the "print at completion" and see if you still have trouble.
Still trying to help,
Ben
Message 13 of 16
(1,187 Views)
Ohhhhhh. Tada!
You are correct.
Can you explain that to me? Why was that causing an error? I would have never thought of that, I didn't even know it was turned on.
THANNNNNNKS!
Message 14 of 16
(1,187 Views)
I mentioned it because I noticed the printer icon show up after running my quick hack.
Ben
Message 15 of 16
(1,187 Views)
uscmagz wrote:
> Ohhhhhh. Tada!
> You are correct.
> THANNNNNNKS!
It doesn't work and crashes because you don't have a printer installed
on your machine or it is not connected. You said stated this yourself
in a previous posting that you don't have a printer connection. This
issue has probably been rectified in LV7.1
> WHat do you mean print the front panel without
> errors. I see its set to "print at completion" (the computer I use
> does not have a printer connection) but do you mean save the front
> pane
l to file without errors?
Michael Aivaliotis
http://mmwis.com
http://forums.lavausergroup.org
http://niweekblog.com
Michael Aivaliotis
VI Shots LLC
Message 16 of 16
(1,187 Views)
