Why LabVIEW can be only closed via task manager (still)?
What you can do is to check if Windows Event Log shows up weird things. Maybe you can find out the source (DLL, EXE, ...?) of the zombie behavior.
Norbert
Norbert
Expert: Geometry
Message 11 of 16
(1,511 Views)
What is funny, that I did not have this behaviour since I started this thread...I guess the bug got scared of you people??? 😄
As a workaround (speed up the kill task procedure), I installed again the handy tool from :
https://lavag.org/topic/11333-labview-tray-launcher/?do=findComment&comment=116021
Message 12 of 16
(1,510 Views)
Hey that's me.  Yeah I've been meaning to update that, I think there is a bug with sometimes not opening a VI in the selected instance.
Anyway to be on topic a bit.  The only time I saw something like this, is when I was using a toolkit that was opening VI references and not closing them.  If you waited a realllly long time LabVIEW would close itself on exit but it took forever.  This also manifested itself in built EXEs.  It took quite a bit of testing to isolate it and reproduce it to find the place where a close reference was needed.
I don't think this is your situation because you claim it happens on simple VIs from the forums.  I'd just try to come up with a set of steps that can reliably reproduce the issue, and then try to isolate what is causing it.  But I would suspect is is some kind of plugin that is loaded, and not the unclosed references that my issue was.
Message 13 of 16
(1,494 Views)
Hmm, I will try to reproduce the bug when I use the LAVA Code Capture Toolkit...It might cause the bug...?
Message 14 of 16
(1,487 Views)
No, at least not after one try: I have created a snippet, but I was able to exit LV properly after that...
Message 15 of 16
(1,480 Views)
I have seen this and it is usually due to a reference not getting closed or a front panel window that was hidden but the VI not closed.  To help troubleshoot, right click on the LabVIEW icon on the task bar.  That should show a list of recently opened VI's.  Choose any one of them.  After that VI opens, choose View->VI Hierarchy from the LabVIEW Menu.  It will show the VI that you opened as well as any other VI in memory.  This may help you track down the issue.
CLA
Message 16 of 16
(1,449 Views)
