Why LabVIEW allows characters within Numeric control
Why LabVIEW allows characters (Key down) within Numeric control,
When I hit Enter button, it’ll clear all the characters and returns to 0.
My question is why does it allow specific characters(not all)?
Best Regards
Shankar
Message 1 of 11
(6,170 Views)
Accepted by Shankar*
It is done for user convenience.
So to enter 5000 you can enter 5k, or to enter 0.000005 you can enter 5u.
LabVIEW allows you to enter text then validates it after you hit enter.
Hope this helps.
Thank you,
Khachik Sahakyan | CLA
Message 2 of 11
(6,155 Views)
Thank you Kachik 🙂
I do agree that it's really useful, if I change the data type(representation) to U8 then I dont think most of these units are applicable!!
Best Regards
Shankar
Message 3 of 11
(6,139 Views)
Yes, for example 5u will return 0 and 5k will be 255 🙂
Thank you,
Message 4 of 11
(6,122 Views)
It's also how you enter Not a Number (NaN).
(blog)
Message 5 of 11
(6,115 Views)
Also things like "1E+3", as well as "Inf"
Message 6 of 11
(6,080 Views)
Hi Sankar,
if it disturbs you, you can use an event structure to filter any unwanted chars while the user is typing them…
Message 7 of 11
(6,071 Views)
Hi GerdW,
Thanks for the suggestion 🙂
I wanted to know the reason why It's not been implmented as part of the control, but allowing these chars(units) does make sense 🙂
Kind Regards
Sankar
Best Regards
Shankar
Message 8 of 11
(6,063 Views)
Bottom line: What is a numeric control ?
A String !
A numeric Windows object (not talking about G object) is just a text box limited to numbers.
In C language, U8 is defined as char
In LabVIEW, you can re-format a numeric control, and use it as a string.
George Zou
Message 9 of 11
(6,029 Views)
George Zou
Message 10 of 11
(6,025 Views)
