Why Do I Get "Unable to browse OPC Server from the selected machine. Error -2147024891 occurred at GetOPCServerList.vi" When Trying to Connect to remote OPC Server?
Software Version:
LabVIEW 2013 (32bit)
Windows server 2008 r2 (64bit)
OPCenum.exe installed
(7,596 Views)
Artyom,
What are you running when you get this error?
(7,572 Views)
When i am using NI Distributed System Manager, adding process and then adding opc io server
(7,560 Views)
Can you confirm that the OpcEnum service is running by going to Start - Control Panel - Administrative Tools - Services?
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(7,549 Views)
Andrew T.
Yes, it`s running.
Here is a screenshot services window
(7,537 Views)
What does your setup look like? Is the server hosted on the same machine as the process that is throwing the error?
It might be DCOM settings. This webpage gives a rundown of how to configure most of the DCOM settings that should be important.
Andrew T.
(7,519 Views)
