Why AND Array function gives true for empty array elements ?
In first the array control is empty the AND Array Elements function gives the result as True, is it correct  behaviour ? Explain me !
After inserting boolean conditions to the array control it works correctly.
i am using labview 7.1
screenshot attached.
-Kumar B.
Message Edited by Kumar B on 05-10-2007 12:50 AM
(4,638 Views)
Hi Kumar,
this is expected behaviour and (supposedly) mathematically correct:
see here,
Ton
My LabVIEW Ideas
(4,619 Views)
Ton,
It is supposedly MATHEMATICALLY correct, is it LOGICALLY correct... ?! Smiley Wink
Just joked ! Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
(4,611 Views)
Another test to check the logic of your mind : What is the expected result of Check if File or Folder exists.vi with an empty path wired to it ?
And the answer is...
Message Edité par JB le 05-10-2007 09:30 AM
(4,601 Views)
Without any doubt the answer in "True"
Empty path is the root ("/") path.  On windows and mac this is an imaginary folder that contains all the hard drives as subdirectories. On linux, this is the root / directory.
Side note : what happens if you launch "Delete Recursive function" with an empty path as input :-o, be carefull !
Epictetus
Antoine Chalons
(4,592 Views)
