White space in cell in excel - with CLAUDIE_xlsx addon
Hi everyone.
I tried using CLAUDIE_xlsx addon on LabVIEW in order to write and read data from an excel file.
I succeeded with creating, opening and writing to an excel file.
But when after I write text to spreadsheet in excel, I see that in addition to the text in the excel file, there is a blank cells without the excel cells boarders.
This is the blank cells in the excel file:
And here is the LabVIEW connections:
Do you know how I can fix this?
Also, is it possible to read a specific cell from a spreadsheet in excel or only a specific row? if it's possible, how do I do it?
Reshef
(3,551 Views)
Accepted by resheffink
Hi Reshef,
You seem to write a lot of empty strings to your sheet - as far as can be seen from your blurry image…
Yes and yes.
Usually you can do this using ActiveX calls to remotely control Excel.
I don't know how your CLAUDIE toolkit handles those calls - have you read its manual or tried to contact the support?
(3,534 Views)
I've found the problem. it needed a const length of array to be inserted into excel. now everything works fine.
Thank you for your help!
(3,440 Views)
So im trying to read an excel file with labview in order to display some data on led screens.
When i tried a simple VI, as a first step, to read an excel file it returns an error code 10 : duplicate path.
I used Claudie_xlsx addons which doesnt require activeX.
I have searched in google for some samples but i guess people are not familiar with Claudie addons.
I have attached the some screenshots.
Dhafer 
(3,190 Views)
I have an existing excel with 2 blank sheets. When I write to sheet number 2, the style of sheet number 1 disappears. Does anyone have experience with the addon and can help with an example of writing to Excel correctly?
(479 Views)
