While Loop to Monitor a 1D 8Bit boolean Array for changes
Hi;
I need help in monitoring a 1D 8-bit boolean array for a value change. I think I need to use a while loop with shift registers???
Any suggestions?
Thank you,
4BoysDaD
Message 1 of 9
(4,478 Views)
Where are you going to put it in your code. It will depend on what you are already doing. Here is an example to show you how to do it with out shift registers.
Tim
GHSP
Message 2 of 9
(4,476 Views)
duplicate post
Why did you create a new thread when you were already being helped in the other thread?
Message 3 of 9
(4,468 Views)
Hmmmmm.... 😄
Message 4 of 9
(4,459 Views)
I apologize.
I am still getting use to the Dos and Don'ts of Forums.
4BoysDad$
Message 5 of 9
(4,456 Views)
Hi; The attached image is what I am working with. The senior programmer, who is out of town, said I should use shift registers in combination with the while loop and a For Loop to read the current values of the Requests array. I am then to compare the old values to the new. Any help is greatly appreciated. 4BoysDad
Message 6 of 9
(4,447 Views)
Please continue in the other thread to keep it all in one place. What is wrong with the solution there?
Message 7 of 9
(4,431 Views)
How do I get back to the other thread?
Message 8 of 9
(4,428 Views)
Click on the link I have in message #3 and do your replies there.
Message 9 of 9
(4,419 Views)
