Monitor 1D Boolean 8Bit array for Changes
HI;
In the attached VI, I'd like to continuously monitor the the 8 switches (1D 8-bit Boolean array) for any changes in value and which switch changes.
I'd also like to clear the switches on Stop.
Any suggestions?
Thank you.
4BoysDad
Message 1 of 17
(3,894 Views)
Accepted by topic author 4BoysDad
Message 2 of 17
(3,887 Views)
Could you please explain how to create that VI invoke node?
And why you choose invoke node instead of property node?
Thank you
Message 3 of 17
(3,875 Views)
  • Place an invoke node from the palette, right-click the top and select class :VI server...VI..VI.
  • Click the method and select defautl value...initialze to default
This will do it for all controls and indicators on the front panel in one step. Seems easier. :D.
Message 4 of 17
(3,861 Views)
Of course you can further simplify your code dramatically if you would use an array of switches on the front panel instead of 8 seperate switches. Make the array size 8, all false, and make this the default.
Message 5 of 17
(3,859 Views)
Thank you altenbach. Have a nice holiday!
Message 6 of 17
(3,837 Views)
Thank you for the suggestions.
How might one capture which of the switches changed value and the associated value? I think I could use a switch that holfd its True (selected) value only so long as the switch is held. I would need this switch type to get back to the feault state automatically. What do you think?
4BoysDad
Message 7 of 17
(3,799 Views)
I don't understand what you mean by the rest of your comment, but to find the changed boolean, simply do a "not equal" comparison in "compare elements" mode and search for TRUE. If the result is not negative, use "index array" to find the new value.
Here is a simple example.
Message 8 of 17
(3,789 Views)
Thank you.
What if I had a refnum to the 1D 8 bit boolean array?
I assume I would use a similar technique if not the same technique.
4BoysDad
Message 9 of 17
(3,785 Views)
Yes.
(You can always have a refnum, but why would you use one at all here?)
Message 10 of 17
(3,781 Views)
