Which kind 3D format file can be used by LV
I will try to make a 3D model and display it in labview, then make it can turn and mark.
May I know which kind 3D format file can be used by LV, thanks.
(6,658 Views)
From the LabVIEW help, LabVIEW currently supports ASE, STL, and VRML formats.  There are VIs in the 3D Picture Control VIs palette to load these files into a 3D scene graph.
(6,644 Views)
Is it possible to learn the main software of this 3 kind file formats from you.
What is there advantage and disadvantage, thanks.
(6,631 Views)
I download a .skp file from http://sketchup.google.com/3dwarehouse/details?mid=78cc2f590f41c50242471a633f328705
Is it possible to convert to one of the 3 kind of files.
Thanks.
(6,627 Views)
I am not familiar with ASE, but can give you a little info on the other two file formats.
STL is a simple, triangle based, file format used by many pieces of software.  All the major CAD programs can export it.  Examples are AutoCAD and SolidWorks.  Due to its simplicity, it is probably the best supported.  It is also the most commonly used file type for 3D modelling (e.g. stereolithography, selective laser sintering, 3D printing).  You can get instructions on how to convert from a .skp to a .stl here.  I have not tried them so cannot vouch for their accuracy.
VRML format was invented for virtual reality simulations.  It has remained somewhat popular.
A net search on any of these formats should get you a lot more information.
(6,614 Views)
There are 3D model viewer/converter software packages available.  Search around and I'll bet you can find a free one. Here is a start:
http://www.3dlinks.com/links.cfm?categoryid=1&subcategoryid=11&CFID=56265351&CFTOKEN=81396344
EDIT:  Also don't forget to see if Google Sketch (or whatever you're using) can save or export into VMRL or STL.  Most 3D modelling software can do that.
(6,611 Views)
Accepted by alex.
You can export the model as .STL and use it in LabVIEW.
See
Import 3D Models from Google SketchUp into LabVIEW
http://decibel.ni.com/content/docs/DOC-5242
Hope this helps.
Andy Chang
(6,597 Views)
