Which harware should I select (PXI or CompactRio) for high sampling rate acquisition
Hi all,
I would like to acquire some signals with high sampling rate (1 MHz and above) and save the data.
Which hardware should I select (PXI or Compact Rio)?
For PXI, I read that we can select different multi-function data acquisition card for different sampling rate, which includes card with high sampling rate.
How about Compact Rio? From what I understand, the sampling rate depends on the sampling rate of module?
Please give some advice.
Thank you. Smiley Happy
(2,792 Views)
Can you explain a little more about what you're acquiring? How many channels? What you intend to do with the data?
A CompactRIO can handle 1MHz, but if you're acquireing from 16 channels and intending to process the data as well as stored it, then you'll probably want a more powerful PXI.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(2,786 Views)
Hi Thoric,
I'm planning to acquire the vibration and acoustic emission signals, 4 channels, I intended to acquire and store the data over a period of time.
Is the 1 MHz simultaneous sampling? What is the max data storage for Compact RIO and PXI?
Btw, what is the main difference between Compact RIO and PXI?
Thanks for helping. Smiley Happy
(2,775 Views)
