Which are the equivalent functions in Labview to DB-Transfer functions used in C
Which are the equivalents functions in LabView to
DB-Config functions
DB-HalfReady functions
used in C.
(2,634 Views)
Within LabVIEW the WFM_DB_Config will be replaced by the AO Config VI. The WFM_DB_Transfer and the WFM_HalfReady functions will be replaced by the AO Write VI.
I would suggest to look at a double-buffered analog output example written in LabVIEW to better understand how to program this type of application. The Generate Continuous Sinewave VI shipping example shows how to perform a circular-buffered operation. For a double-buffered operation, you would just continue to write data using the AO Write VI within the while loop. I've attached the shipping example if you have trouble finding it. I hope this helps.
Todd D.
(2,634 Views)
I need make others activities at same time that I take out data, read encoders specify. This example is OK, but when I use a big data file, only I can take out data but I can't read encoders. Using the same example in the loop when I reload buffer always read all data file and I need read only the next 500 data (or 1000,for example), I need have control about the data tranfers to buffer. I want always read the encoders and reload the buffer only with the next 500 data (no all data, like in the example) when halfready is set using DMA transfer.
(2,634 Views)
