Which alpha-numeric keypad is best suited to Windows CE and where can I get it?
I am using a NI TCP with a RIO, but need an alpha-numeric keypad to operate the system. Which is the best to use with Windows CE and where can I download it?
Regards
Justin
(4,127 Views)
If I understand correctly what you're looking for, there are some interesting links where you can download demos : LV Alphanumeric Keypad
or examples in NI Developer Zone
I hope it helps.
Message Edité par Steve Mohamed le 01-20-2009 05:12 PM
Steve M.
(4,118 Views)
Thanks Steve I found a few usefull keyboards on those links. At the moment my project is still in develpment and I am waiting on the delivery of my TPC-2006. The problem now is when I try to save the target on my project using the mobile module there is no option to select any TPC as a target, only pocket pc or emulators. Is this because I physically dont have the TPC connected?
Regards
Justin
(4,087 Views)
No because I don't have a TPC connected and I can select and add TPC in my project. In your project explorer select your project/New/Target and Devices and you'll get this following window :
I hope it helps,
Regards
Steve M.
(4,062 Views)
Hi Steve, thanks for all your help so far much appreciated. I did as you stated, I selected your project/New/Target and Devices but I do not have the Touch panel folder available for selection. I uploaded the PDA module as I understand this gives access to the mobile folder but is there any additional modules I have to upload to gain access to the Touch Panel folder? Sorry I couldnt upload a sceeen shot.
As of now the only folder available for selection are - DSP, Fieldpoint network Modules, Mobile, Real-time CompactRIO, Real-Time fieldpoint, Real -time PXI and Real-Time Singler-Board RIO
Regards
Justin
(4,037 Views)
Of course you're not able to find the Touch Panel devices because you didn't installed the Touch Panel toolkit (Touch Panel Deployment License). You will find a license on the delivery of your TPC 2006 and then you'll be able to add your module to your project.
Message Edité par Steve Mohamed le 01-23-2009 03:41 PM
Steve M.
(4,028 Views)
Steve, I  recieved the TCP 2106 and  it saved as a target in a project on my PC. I was able to deploy a simple program down to the TCP and run it. I then tried to deploy a more complex program but Labview would not comile the program to an executeable, Labview returned an error messege "Unable to build executeable for an unknown reason contact National Intrument". I have attached the build log that was created when Labview tried to build the executeable. Can you help please?
Regards
Justin
(3,849 Views)
