Which algorithm does Sort 1D Array use?
Is it one of those listed in Wikipedia?
If not:
  • Is it a constant-memory algorithm for all data types?
  • What is its worst-case complexity?
  • Is it stable?
(4,929 Views)
I believe a version of quicksort is hidden under the hood where we don't play.
It is not a stable implementation since the entire data becomes the key for complex data types with simillar elements
"Should be" isn't "Is" -Jay
(4,911 Views)
Can anyone from NI confirm? I need to know the stability and memory utilization for sure before I put it to use.
(4,902 Views)
I challenge you to write your own that outperforms the stock sort algorithm. 😄
Besides, you can easily test it yourself with some simple benchmarks using arrays of various lenght, either random or with some pathological pattern (all the same, all NaN, some NaN, already sorted, reverse sorted, etc.).
Things like sorting are very well studied and I am sure that NI put a lot of thought into it. What prompted you to question the sorting algorithm?
(4,886 Views)
I don't remember challenging the quality of the primitive's implementation; I was just asking for more information about it.
One of the most frustrating experiences about posting on the NI forums is that invariably someone, either from NI AE or a community member, will challenge the reason you asked for information or help at all. I want to know the characteristics of the sorting function because I want complete control over the performance of my low-level LabVIEW code. That's reason enough.
(4,872 Views)
Well, if you need to sort and the NI implmentation does not fit your needs, you would have to write one yourself. Right?
As I said, it would be trivial to write a benchmark testbench geared towards your exact use case (datatype, size, typical patterns, etc.). Why haven't you done that yet?
It is even more frustrating if users fill posts 70% with philosophical comments.
You cannot get "complete control", because sorting depends on the input.
If NI uses their own algorithm, it is most likely proprietary and they won't tell you the details.
Chances are they are using some known library.
(4,866 Views)
