Which Component is the limiting factor?
Greetings.  A previous employee at my company had set up a an Instron Universal testing machine station that communicated with Labview via GPIB.  This station has served us well for the past 6 years but now we need to upgrade and I am not sure which component to upgrade.  Sorry this my first experiance with labview (other than using the gui front).  In the past few days I have read the Labview manual and it seems intuitive enough.
Pretty much all I want to do is read my load and position many more times per second.  From reading other posts and the manual I was able to move the I/O instrument assistant into a flat sequence structure and surrond it by two millisecond timers.  This confirmed that the I/O intrument assistant is the limiting factor in the block diagram.  Currently we are getting readings about every 160-220 ms (it is surprisingly inconsistant).  This is about the same value I am getting from the timers.  I would like the delay between readings to be more like 20ms or even 2 ms.
Here is my system breakdown:
Labview 7 Express
Windows NT 4.0
Pentium 2 400MHz
NI PCI-GPIB card
Instron 8511 Controller
In order to get the performance that I desire which components do you think I will need to replace and what tests can I do to learn more?
Any help is greatly appreciated.
-Daniel
Message 1 of 15
(5,029 Views)
You really need to break things down a bit further before blaming the assistant and asking for help. You haven't provided any information on what you have set the assistant to do - i.e. how many steps there are, how much data you are writing, how much data you are reading.
You could try using VISA Writes and Reads instead of the I/O Assistant but the bottlenect could very well be the Instron. A write/read cycle time of 200ms is not out of the ordinary and a 20ms time for GPIB would be very fast and unusual. The manual from the vendor should specify the GPIB transfer time.
Message Edited by Dennis Knutson on 08-25-2009 10:55 AM
Message 2 of 15
(5,023 Views)
Dennis:
Thanks for your rapid reponse.  Below are some screen shots of my I/O assistant.  I have already read all three 400 page manuals to the Instron and it says absolutlely nothing about parse or response delays.  All it says is that it has 1.5 Mbyte/s GPIB.  I am very dissappointed with the manual.  I am thinking that I will call Instron customer service.
-Daniel
Message 3 of 15
(4,998 Views)
Message 4 of 15
(4,997 Views)
It looks like you have 3 separate read/write actions so ~70 msec would not be unusual. The stated rate may be accurate (though you need a GPIB board that supports it - it's non-standard) for just the data transfer but as you said, the instrument's time to receive and process the command could be significantly different.
Message 5 of 15
(4,974 Views)
Accepted by Crusher
The user?  SCNR
The GPIB speed of your Instron just tells you that it would be able to send you the data fast enough. I don't know that instrument, however I would dig into the manual to find out if it is possible set it up in a way it could make use of that speed. Maybe by internal scripts, hardware triggered acquisition, lower resolution....  request 1000 values once instead of one 1000 times.
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 15
(4,952 Views)
Henrik:
You actually guessed correctly; you can set it up to send 1000 values instead of 1 value 1000 times, however this will give me disjointed data because I need to record data over several minutes.  The buffers on the Intron are not nearly large enough.  I would have to request multiple sets of 1000.  (I think that the buffer only holds about 1000 pieces of data.)  Plus I could not display the data live this way.
It looks to me that GPIB will never give me what I want.  I think my best option will be to use a different DAQ that can read the analogue outputs.  If I swaped out the PCI card and read the analogue output with everything else the same, do you think I will obtian my goal of 20ms?  Do you know off the top of your head if Labview can support two PCI cards simultaniously?
Message 7 of 15
(4,940 Views)
Hi Crusher,
Yes, LabVIEW can handle multiple DAQ boards in one computer. You can synchronize over RTSI if need be. I would recommend calling a sales person and they would figure out the best cards for your requirements.
http://sine.ni.com/apps/utf8/nicc.call_me
Jeff | LabVIEW Software Engineer
Message 8 of 15
(4,920 Views)
Crusher,
if you want a scale able system for industrial use look for a PXI Sytem. (Personal fav. ) However start with a complete requirement list ( with columns for "current need", "known future need", "nice to have")
And request / reflect the requirements. For example: "We NEED a 500kHz 10ppm voltage measurement with live display to monitor the temperature"
Henrik
LV since v3.1
Message 9 of 15
(4,879 Views)
Thanks for the suggestions.  If I were to add analogue capabilities, I would need 1kHz at 10000ppm accuracy :).
I talked to a tech at Instron and he says that it is possible to send blocks of data over GPIB without having gaps between the blocks.  I am going to try to get this to work.
Message 10 of 15
(4,865 Views)
