cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Where to start
Resolvido!
Ir para a solução
I would to know how is it possible to import data from txt file into columns if i have lines like V=0.1 mL; pH=1.4019;
Thanks in advance!
Mensagem 1 de 15
3.735Exibições
Start with the Examples that are included with LabVIEW.
Mensagem 2 de 15
3.734Exibições
The function "Read From Spreadsheet File" on the File I/O pallette would be a good place to start.
Good luck!
Mensagem 3 de 15
3.692Exibições
Could anyone write me a sample program how to import this data into a table and perform math operations on them, please
I would appreciate it
Mensagem 4 de 15
3.663Exibições
Sure, how much are you willing to pay per hour? Piscadela do Smiley
Did you even try anything yourself? Looking at the examples or looking at the file/string functions?
Mensagem 5 de 15
3.656Exibições
yep i tried, but the problem is, that i couldn't manage how to import data into the table, because it has numbers and string, the best i've got is just two numbers and thats all..
Mensagem 6 de 15
3.652Exibições
Obviously if you want to do math you're going to have to use numeric data types.
The strings seem to be always the same, do you really need them? If so you could create 2 arrays, one with descriptors (strings) and a second one with the numbers (DBL).
Have a look at the scan from string or scan from file functions. These can handle strings and numbers.
Mensagem 7 de 15
3.644Exibições
start with NI LabVIEW 101...Piscadela do Smiley
then look at the "string" and "string/number conversion" pallet, ultimately it all has to be converted to a string file..
Mensagem 8 de 15
3.642Exibições
Thanks guys, that was very helpful!
Is it possible to multiply number by 10 to the third power?
Mensagem 9 de 15
3.584Exibições
Multiply by 1000?  Look in the numeric palette and you will see a quite obvious multiply node.
Mensagem 10 de 15
3.580Exibições
