Where is the Variant Constant?
Why does LabVIEW not have a "variant constant" on the Functions Palette? The easiest way I have found to create one is to
1. Drop a Convert To Variant function onto the block diagram
2. Create a variant constant off of the Convert To Variant input terminal
3. Delete the Convert To Variant function
OR
1. Create a variant control
2. Go to the block diagram and select Change to Constant
Just seems odd to me.
Craig
(3,243 Views)
OR
Craig
OR
select a varaint control Drag to the BD Drop ( dropping any selected control on the BD creates a constant of that type- useful for Type Defs)
Sounds like a good proposal for the Idea ExchangeSmiley Wink
"Should be" isn't "Is" -Jay
(3,235 Views)
The input of the To Variant function is actually a cluster of 0 zero elements, you need to create a constant off of the output.
At one point I felt like it was an ommission, but I don't really know when I would use it in place of create constant.  What uses for the constant do you have in mind?  9 times out of 10 I am using the constant to initialize a shift register, and I am only using the variant for its attributes.  Very easy to right click the SR and create constant.
You should see this idea:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Variant-constant-to-the-Cluster-Class-amp-Variant-...
(3,224 Views)
