Where do I find a VI to graph the analog output of a chromatograph with 3 outputs (black-white-brown)?
MH5000,
I must assume here that you are using a DAQ card to get the data into your PC. From here I suggest using a built-in example for LabVIEW called Cont Acq&Graph (buffered).vi. This example allows one to read multiple channels and plot them on a graph. If you want the three colors you describe, then you can change them by right-clicking on the plot legend and changing the plot colors. (You will also need to change the plot backgroung color away from black using the Coloring Tool.)
Randy Hoskin
http://www.ni.com/ask
(2,544 Views)
