When using IMAQdx Snap2, the left and right sides of the image are sometimes swapped.
I am creating an application for image capture using the above IMAQdx Snap2.
This application acquires images from a USB 3.0 industrial camera.
Under normal conditions, the following images are obtained.
However, occasionally, I am faced with the trouble of getting images with the left and right sides of the image swapped, as shown below.
The part of the square with the right side cut off is on the left, and the rest of the square is on the right.
If you know of a solution, could you please let me know?
(1,173 Views)
Quite interesting, I haven't seen such issue with USB cams, but have seen with CameraLink (or NI PCI 1424?), where Line Sync was unstable, caused such shift.
As very first suggestion I would like to recommend to upgrade possible newest compatible version of the VAS if not done yet.
In the compatibility chart the lowest listed LabVIEW is 2018, but for LabVIEW 2017 is the 20.6 should be OK.
Have you seen this with IMAQdx Snap2 only or also with MAX software as well?
In general USB should transmit image frame by frame and not pixel by pixel/line by line, so it looks like internal camera issue. USB transmission should not affect image in such form.
Are you using any kind of hardware triggering with your cam?
(1,152 Views)
Thank you for your comment.
The version of VAS was 17.5, I will update to 20.6 and try it.
This phenomenon is only on IMAQdx Snap2.
It did not occur no matter how many times I tried Grab or Snap with NI MAX.
The trigger for this USB camera is software trigger.
As additional information, this was not a problem when I was using this software on windows 10, but since I started running it on windows 11, I am experiencing this phenomenon.
(1,099 Views)
Then may be makes sense to try other examples shipped with IMAQdx, they are slightly different, may be you will found code snippet which is free from this problem. When I have had similar issue with Camera Link (but that was "horizonzal" split), caused by wrong sync (but it was 30 meters cable with repeater), then I fixed this programmatically, means each frame was "inspected" for such shift by edges detection, then "splitter position" was determined, then image "shifted back" programmatically. Was no other way, we tried different cables and repeaters and without success, nothing was helpful except self-made software correction. So, the users haven't seen that internally we have such problem.
(1,093 Views)
Thank you very much.
I will try it.
(1,083 Views)
Accepted by yuwatanabe
I changed from IMAQdx Snap2 and did a snap with NI-IMAQdx Low-Level and the problem no longer occurs.
Incidentally, the bug occurred even after changing the OS of the relevant PC to win10. Since the bug did not occur even with snap2 on another PC, we assume that it is caused by a compatibility problem between the chipset of the motherboard and the USB camera driver.
(1,017 Views)
