When and How to get the Text.ScrollPos value of a String control when scroll bar position changed
I'm working on a feature triggered by scroll bar position of a string control changed.
But I could not find a good way to catch the scroll bar position changed event,
the scroll bar is controlled manually by mouse down → mouse move → mouse up, I want the get the Text.ScrollPos value when user mouse up, and compare with the maximum value.
But the problem is,  mouse up on the scroll bar could not trigger String: Mouse up event!
So I have to get the Text.ScrollPos continuously in the background in Timeout event, but I think it’s not efficient.
Do you have any better idea on when to get the correct destination value of Text.ScrollPos?
I plan to store the value of Text.ScrollPos in the bottom(maximum value) in a shift register, then compare the current Text.ScrollPos value with the max one.
If it comes close to the bottom(90%~100% of the maximum value), then the close to bottom LED will turn on.
(3,285 Views)
Hello Cecilia,
I don't think there is any build-in event for this.
One solution would be to create your own user event at the initialisation of you main and launch a thread which is going to be pulling the value of your scrollbar position:Scrollbar event.PNG
Then you can build your main as if they were a scrollbar move event.
And dont forget to close the thread and destroy the event at the end.
Hope it helps.
(3,251 Views)
