What .vi needs, include...
Let's say I have one .vi in some folder. Is there any option in LV to show me lost of which all .vi call my .vi. I must know that because if I move for example this .vi, it will searching for missing .vi....
thanks
_________________________
Rookie; LV 2011 on WIN 7
(4,115 Views)
You can find callers within a project. There is no way to do that outside of a project.
LabVIEW 2012
(4,112 Views)
so if I don't have it as "project"(just main .vi) then I can't know what is included?
(4,110 Views)
View>>VI Hierarchy
Play with it some lots of good things to look atSmiley Wink  very nice for finding callees-
 Finding all callers takes a different, but simillar, approach
Without a "Project" you need some other structure that holds all your vis so you can browse relationships.  This is commonly called a "Tree.vi" by viewing the heirarchy of  Each Tree.vi (Or, I once saw a "Forest.vi"- it had a lot of Trees in itSmiley Wink) you can find all callers within any "Scope" or "Tree"
"Should be" isn't "Is" -Jay
(4,105 Views)
You need a project if you want to find "callers" of a VI. If you want to see "callees" you can use the view hierarchy.
LabVIEW 2012
(4,097 Views)
Accepted by topic author hlod
There's also the Save As... -> Duplicate Hierarchy option, which will copy everything that your VI requires into another directory, maintaining the relative directory structure.
(4,096 Views)
