What spreadsheet format to capture all data?
Sorry I realize this isn't exactly a Labview question, but I'm writing all of my DAQ data to a spreadsheet file (currently just using an Excel file) but now that I'm sampling at a higher rate I am getting too much data for Excel to import (it will only do 6XXXX rows before it says all of the data was not imported). I need to really use the data in Matlab so I was just curious what format is better so that I don't lose any of it. Should I just use a .txt file and try importing that into Mablab (not as easy as an Excel sheet)
(2,816 Views)
If it is a comma delimited file, then the fact that excel can not open it, does not mean that the data is not there.  You just can not view it in Excel.  You can probably still open it in notepad though.
Paul
(2,806 Views)
If you use plain ASCII (txt) every math program will be able to read it. (I personally wouldn't call Excel a math program Smiley Wink)
Matlab can also read binary files, just in case your data files will increase and file size starts to matter.
Greetings from Germany
Henrik
LV since v3.1
(2,789 Views)
Thanks gentlemen, I got it working fine again.
(2,771 Views)
