I've been recently introduced to LabView, and in my current project I've created an "Enum Constant" with 9 items. Le'ts say, for example, each item says:
"First Item"
"Second Item"
"Third Item"
...etc
then I created a case structure, and used the "Add case for every value" option.
My problem is that later on, I noticed that in the Case Structure, my cases show numbers "0, Default" "1" "2" ... instead of saying "First Item" or "Second Item" .... etc
I don't know what in the world I've done to change the display of the values, and I can't figure out the way to change it back lol
Side Notes:
--The enum constant (obviously attached to the case structure) still has the same values "First Item" "Second Item" "Third Item"
--The enum constant (again, attached to the case structure) has a tunnel that goes through a While Loop with a Shift Register, and there's a little coercion dot right there at the input terminal. I don't know what to do about it.
-- I can't attach the VI for moral reasons, so I tried to explain my problem as simple as I could
