What other devices can I use that is similar to PCTx and allows me to transmit labview to a RC controller
Hi
My project is to find out how Labview can interface with RC controller.
Beside using Endurance R/C - PCTx (http://www.endurance-rc.com/pctx.php), what other devices can I use that allows me to transmit labview to the controller.
The controller I will be using is Futaba T10CAP (http://www.astramodel.cz/manualy/futaba/futaba_10cp_eng.pdf)
Thanks and regard
(3,815 Views)
Neither of your links work.
What sort of connection are you trying to use? Is there a USB or serial connection? What sort of api from the vendor allows for remote control?
(3,794 Views)
 Sorry hope the links below works:
Endurance R/C - PCTx (http://www.endurance-rc.com/pctx.php) or (http://www.endurance-rc.com/howitworks.php)
1) Any connection is fine as I would like to know the different types of possiblity.
2) The controller uses a serial connection port.
(3,763 Views)
The only connection I see with a quick glance is the trainer link. So, if you can get the specs on that, you can probably build you own interface. Where in the long manual do you see a serial port described?
(3,756 Views)
What's wrong with buying the PCTx?
(3,748 Views)
Their Labview demo problems doesn't work on the PCTx, so I need an alternative 😕
(3,682 Views)
