What is wrong with the DAQ 6221
Hello!
I was able to set my program to aquire the max voltage and P2P values, thank for the helpers.
Now, I have a very specific issue with the NI-DAQ 6221, it seems that when I stream the data to the amplitude and measurments VI and try to get the P2P, I get "0" (not boolian, a 0 value of the P2P) while getting 2V on the Max voltage. (dosen't make sense)
I looked into the belly of the amplitude and measurments VI and ran a debug, and noticed that it subtcates the max voltage from the minimum voltage to get the P2P, and that it recieves identical values in both Max voltage and Min voltage.
I have examined this further, and placed a program generated sin signal instead of the DAQ, and it works as it should, giving me the max voltage as I specify and P2P normally.
I use a signal generator that connects the scb-68 connector board, if this info will help in finding a solution.
Has anyone encountered this problem? do you know it's source and how to solve it?
(3,136 Views)
Why don't you make it easier for everyone and just post the code. I'm confused by what you are saying. What does 'subtcates' mean? and what is 'ran a debug'?
(3,120 Views)
I think he meant to type 'subtracts'.  In any case if your canned sin wave data is working it must be a problem with the data coming in from the DAQ.  Probe it or set up an indicator (graph) to view it before it goes into the measurement VI.  You probably have a DAQ parameter configured wrong.
As Dennis said, posting your code will help us help you.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,103 Views)
If your max and min values are the same, it means you are sending (or acquiring) a DC voltage.  Use an oscilloscope to verify the signal.  Also, you could have the min and max input settings to the DAQ Read vi wrong.  For instance, if you are reading a signal that goes from -5v to 0v, and you set your inputs as max voltage=5 and min voltage=0, you will never read the -5v level.  Hence, your max read will be 0 and your min read will be forced to 0 because your input range was set wrong.  I hope this makes sense.
- tbob
Inventor of the WORM Global
(3,076 Views)
