Problem Viewing Boolean Data in a Citadel using HDV
Via my Labview Project/VI, I am using Shared Variables defined as Booleans in a Citadel database.
When I plot them using Historical Data Viewer in MAX, they are not '1's & '0' but huge positive numbers and huge negative numbers.
Yet, when I use the option to Export to Text, what I see in my .txt file is '1's & '0's.
How can I get HDV to plot the correct Boolean values?
Gretchen
(3,328 Views)
Hi Gretchen,
Are the numbers 50 and -50?
thanks
FLash
(3,311 Views)
They are -50 & 50 if I plot using the default Display Settings (right-click and choose Properties).
I have tried resetting the Plot Min/Max to -1000 & 1000 respectively, and what-do-you-know, the values of the Boolean are -1000 or 1000.
I am working with Labview 8.6 and Max 4.50f0.
Gretchen
(3,305 Views)
Hi Gretchen,
I talked to R&D and they said this is expected behavior. The min/max from the properties from the hypertrend properties reflect what is considered as true and false on the chart.
 Is there a reason you cannot set these to 0 and 1?
FLash
(3,289 Views)
