What is this mystery function?
I want to put one of these into a program I am writing but for the life of me I cannot remember what it is called (or where it is located in the panel).
I drew it from memory in MS Paint and how it is wired, though I cannot remember if it sends a boolean true/false or if it sends the value.
It stores a value in memory from the control it is wired to.  If the value doesn't change, it doesn't do anything (or sends a false constant).  If the value does change, it sends the new value (or a true constant).
On second thought I am pretty sure it sends boolean values, though I don't see it in the boolean tab.
(4,575 Views)
Accepted by topic author LarsUlrich
If you're refering to the "arrow" it could be a feedback node..functions>programming>structures
(4,562 Views)
haha I think that is it
(4,548 Views)
So my memory wasn't quite right as to what it looked like, but that was it!  Thank you!
(4,543 Views)
Yeah, and it does not output a Boolean either...
(4,486 Views)
A feedback node does not do that alone. You need additional code, for example a "not equal". (there is also an openg tool)
Here's simple demo. (The LED will light up for one iteration whenever the numeric changes its value.)
(4,445 Views)
