What is the use of the build path function ?
Hello everyone,
i am  a beginner in LabVIEW and i was browsing throught the BUILD PATH function in the FILE I/O section of the Functions Palettte.
i just cant figure out the need for the function, why cant i use just one file path
Thanks in advance
Jal
(2,888 Views)
duplicate post, stick with this one!
(2,880 Views)
You should try using the LabVIEW help documents:  https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/build-path.html
Per documentation:  "Creates a new path by appending a name (or relative path) to an existing path."
If someone helped you out, please select their post as the solution and/or give them Kudos!
(2,879 Views)
