What is the use of the build path function ?
Hello everyone,
i am  a beginner in LabVIEW and i was browsing throught the BUILD PATH function in the FILE I/O section of the Functions Palettte.
i just cant figure out the need for the function, why cant i use just one file path
Thanks in advance
Jal
(2,743 Views)
duplicate post, stick with this one!
(2,735 Views)
You should try using the LabVIEW help documents:  http://zone.ni.com/reference/en-XX/help/371361J-01/glang/build_path/
Per documentation:  "Creates a new path by appending a name (or relative path) to an existing path."
If someone helped you out, please select their post as the solution and/or give them Kudos!
(2,734 Views)
