What is the difference between a cross cable and a straight cable
Hi All,
What is the difference between a cross cable and a straight cable. Which should I use when?
If I need a direct connection from my laptop to my cRIO/PXI controller which cable should I use?
If my Laptop and cRIO/PXI controller is on a network what kind of cable should I use.
Cooldude
(4,249 Views)
A cross cable has some pairs of wires switched internally to connect two ethernet interfaces directly without a hub or switch.
Most modern computers (post 2000) are able to detect if a cross cable should be used and can swith the pairs themselves.
Basically if you get a bad connection (one of the cables is disconnected) you need the other kind of cable.
Here is some more info (wikipedia)
Ton
My LabVIEW Ideas
(4,242 Views)
One note to add to Ton's post.
When uisng a cross-over cable to directly link to nodes, there will not be a node (router etc) to hand out IP addresses so make sure your ports are configured for static IP address.
Ben
(4,211 Views)
To connect your laptop directly to the controller use a CROSS cable
To connect your laptop when the CRIo is over the network(LAN) then use a straight cable.
U can identify whether the cable is crossed or straight just by looking at the ends.. if the wires are actually crossed or not.
Shreyas Hebbare
Shreyas Technologies
India
(4,179 Views)
