What is the best way to stream data from a C-Program to a LabVIEW VI?
Dear Community,
I'm currently working on a project where I'm programming a device control with LabVIEW. A colleague of mine is programming some image analysis with C, where he calculates about 3 paramateres per image every ~30 ms.
Now we want to use these parameters in my VI.
So the idea was to continuously wirte the parameters with the C-Program to a file and simultaneously read from that file with my LabVIEW VI.
For performance reasons the C-Program and LabVIEW VI are running on two different PCs.
My first idea was to use a TDMS file in a shared directory. But after my first tries with TDMS I have some doubts if this is the best solution, because I had some trouble while testing with an .exe to write some TDMS files and simultaneously reading it.
So I just want to ask if you guys know a better solution for our problem?
(4,087 Views)
I don't think using files is going to be the best way to go here.
I think you probably want to use something like a Network Shared Variable.
(4,075 Views)
Accepted by topic author s_bohn
Is there a C interface for shared variables?
TCP is a very good option. STM provides a good template to follow for an implementation. There's even a C client
(4,064 Views)
According to the whitepaper that I linked:
"In addition, with the Network Variable Library introducted in NI LabWindows/CVI 8.1 and NI Measurement Studio 8.1, you can read and write to shared variables in ANSI C, Visual Basic .NET or Visual C#."
I haven't used the ANSI C interface to Measurement Studio myself. Should be pretty straightforward though.
(4,058 Views)
As a possible way to make it simpler, you could use LabVIEW to build a DLL that accesses the shared variable instead of making your C programmer wade through a new API.
(4,047 Views)
Thank you all guys,
I think just using TCP will be the best solution for me.
(3,978 Views)
