09-30-2003 10:16 AM
10-03-2003 09:57 AM
Hi Jim,
Ideally, error-reporting and -handling should be the way to handle this. However, if errors are not reported/handled as is sometimes the case with OPC, a quick-n-dirty way to do this would be to check for a "heartbeat" signal from your OPC Server. This could be a boolean tag which toggles On and Off (or a counter ticking). You then read this Tag in DSC in a slow loop using the Read Tag VI (not the front-panel control). And keep track of the Changed? output from this Read Tag VI.
As long as the 'Changed?' output is true, you are receieving data from the OPC Server, and hence it's alive. You may add some deadband logic to wait for a specific period of time before declaring the Server's really dead!
Hope this helps,
K
halid
10-03-2003 10:41 AM
10-03-2003 11:10 AM
