What is the best way to create a timer that counts up and down automatically?
I want the timer to automatically count up and down from zero to a certain value.
Message 1 of 13
(5,843 Views)
Sounds like a simple application that can be done with a While Loop with some Shift Registers to hold state and counter value.
What have you tried?
Message 2 of 13
(5,829 Views)
I built a countdown timer from this guide, but I don't know how to proceed
http://www.rmuti.ac.th/user/nopparat/document/pdf/LabVIEW_Lab6.pdf
Message 3 of 13
(5,691 Views)
This is what I have so far but it only counts down to zero
Message 4 of 13
(5,812 Views)
I recommend using a boolean (stored in a shift register) to state whether your values are incrementing or decrementing.  Then you just use a case structure for your two different methods.
Message 5 of 13
(5,808 Views)
Honestly, I don't know how to do that
Message 6 of 13
(5,790 Views)
Back out to the main LabVIEW forum page and there are links on the right pointing you to all kids of good learning stuff.
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(5,775 Views)
Think this example can Help You!!!
BR
Certified LabVIEW Architect (CLA)
Message 8 of 13
(5,746 Views)
BR
Not helpful to help the OP cheat by giving him an answer to a problem he should be doing on his own for school.
Message 9 of 13
(5,737 Views)
nyc
That is not my problem, I did not read everyones life history before helping them. He has problem, I try to help, why he is doing that, that his his problem....
Thank You
BR
Message 10 of 13
(5,727 Views)
