‎04-06-2017 10:07 AM
I agree with InfiniteNothing that this would be a nice feature for applications, without needing to build an installer. Here's my solution: in your application setup, on the Destinations category, add a new location called errors. Specify it as <yourAppDir>\user.lib\errors. Go to Source File Settings, highlight MyErrors.txt (or whatever) and specify location as errors. Build. Instruct your customers to overwrite the entire <yourAppDir> with the new one you provide, which will now include a user.lib subdirectory with a sub-subdirectory called errors, with your error file.
‎04-07-2017 11:40 PM
You lost me at "instruct your customers". That's just not going to fly. It's just crazy that something on your block diagram isn't really in your code.
‎04-10-2017 08:36 AM
Fair enough. My customers are all internal to my company, and engineers, so this works for me. But I agree this isn't really good enough for prime time.
‎10-05-2018 05:22 AM
"It's just crazy that something on your block diagram isn't really in your code."
Referring to this I have the question, what is the function of the error rings on the block diagrams? Is it only for readability of the block diagrams?
‎10-05-2018 08:34 AM
Yes, the error ring populates its selections from files ending in "_errors.txt" in specific folders.
Then extends error selection with definable custom codes with format specifier support that are saved elsewhere embedded in code.
_errors.txt can't use format specifies. The text protocol and parsing routines were define ages ago...and are really .... let's give NI something of a break and describe it as "Arthritic "
NXG will improve that according to prophecy.
