Weird behaviour with .NET constructor node and GZipStream compression
Hello Stinus,
A Corrective Action Request with the number 493662 has been filed.
Is there anything else I could do to assist you?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 21 of 35
(4,578 Views)
Hi Thierry
Thanks for the feedback!
I have attached a link to this thread in the 2014 Septembers Monthly Bug list here.
Thanks you very much for your help in propagating this..
Best Regards
Stinus
Message 22 of 35
(4,572 Views)
Hello Stinus,
No problem...
If I can help with other issues, then just let me know.
Kind Regards,
Message 23 of 35
(4,563 Views)
Hi Thierry, any update on CAR #493662? I'm running into this issue also. Does there exist a workaround?
Message 24 of 35
(4,530 Views)
Accepted by topic author Stinus Olsen
Hello Jack,
Sorry for the late reply.
Holidays/vacation came in the way.. 🙂
Currently I cannot provide you with more (useful) updates about the status of the CAR.
There were 3 "work-arounds" that I could think of originally for this specific constructor.
Some of them are better than others:
- Using the dotNET 2.0 version from LabVIEW 2012 SP1 does work, because there is no overloading in this version of the .NET Assembly. (work-around 1)
- Creating your own custom/new Assembly (without these types of overloads) in Visual Studio and calling that one from inside LabVIEW 2013 or 2014 (work-around 2)
- Do not use Assemblies with these types of overloads (not really a work-around), but use alternative ones.
If you want to brainstrom about other work-arounds, then don't hesistate to let me know.
Kind Regards,
Message 25 of 35
(4,499 Views)
For those who might find it helpful I've created a .net assembly in C# that allows you to compress and decompress strings in LabVIEW 2014 using Gzip library. (workaround #2 in Thierry's post above)
Sev K.
Senior Systems R&D Engineer | Wireless | CLA
Message 26 of 35
(4,437 Views)
Thanks for the update and the efforts on this!
Kind Regards,
Message 27 of 35
(4,412 Views)
The compressed string seems to be longer and more character limited than needed.  Is this doing base64 encoding or something?  Do you have a version without such encoding?
Message 28 of 35
(4,170 Views)
Dear all, Yes it is a old thread... but I cannot find a suitable solution... All my data are in the database and not recoverable since I cannot uncompress them. Anyone has a solution yet?
I am using LabVIEW 2017
Benoit
Message 29 of 35
(4,050 Views)
I ended up writing a small .NET assembly that supports GZip compression/decompression with and without base64 encoding..
So, from reading your post it still seems this is an issue in LV2017?
BR
Stinus
Message 30 of 35
(4,046 Views)
