Webservice in LabVIEW 2009
Hi, i am trying to start a webservice as shown in the webcast
http://zone.ni.com/wv/app/doc/p/id/wv-810
I tried it with the same kind of vi(the sum operation). The Webservice is successfully deployed but i cant access it even from the same machine. The address i type in the address bar of internet explorer is
http://localhost/Math/sum/2/5
My webservice name is Math. I am using windows 7, LabVIEW 2009. My project is attached.
Thanks.
LabVIEW 8.2,8.6,2009...still learning 😛
(3,285 Views)
Accepted by wond3rboy
maybe you should try
http://localhost:8080/Math/sum/2/5
The web services port for LabVIEW is normally not the default port (80). It depends on your server settings.
(3,279 Views)
Thanks.
(3,273 Views)
Dear
I am using webservice and now i want to change the default 80 port to some other port.
please tell me the procedure where i have to change the settings and where i can change my server settings.
i hvae tried by changing the port in tools > options but not succeeded.
regards
(3,202 Views)
To change WebServices port please do the following change..
1. Goto Tools->Options
2. Goto Web Server page
3. Click "Configure Web Application Server"
4. This action will open a page in your browser as below. Go and change the port in highlighted section.
Default port for labview webservices is 8080.
AnandSP
Anand kumar SP
Senior Project Engineer
Soliton Technologies Pvt Ltd
(3,193 Views)
