Webcam image acquisition
Hey everyone,
I'm somewhat new to Labview and I've only recently gotten the Vision Development Module and the Vision Acquisition software. It's extremely new to me and I'm at a loss. I searched around and couldn't seem to find exactly what I'm looking for, or maybe I didn't understand it enough to know. I'm really just looking for something to get me started. I'm currently using my laptop and I wanted to create a VI that showed what my webcam was seeing continuously, allows the user to drag and focus on a specific area, and can take a snapshot of the user defined spot.
Ultimately I'm going to use the snapshotted image as a comparison to a later snapshotted image. I'm just looking for somewhere to get started. I've played around with some of the functions and was able to see what my webcam was seeing though I had no clue how to take a snapshot of the image.
Thanks in advance for the assistance.
EDIT: I added a VI of what I'm currently working with that I found from searching around. I'm just stuck at the snapshoting of the defined area(the drag and select tool on image indicator).
(4,289 Views)
I think what you want to do is called ROI... region of interest.
See here for an example:  https://forums.ni.com/t5/Example-Code/Programmatically-Select-ROI-on-Image-by-Clicking-and-Dragging/...
http://www.medicollector.com
(4,274 Views)
Also, you might want to re-post here:
http://forums.ni.com/t5/Machine-Vision/bd-p/200
I often find the vision experts hang out in that forum.
(4,272 Views)
Hey thanks for the reply.
I will post there.
I appreciate the assistance and will look into the ROI stuff.
(4,265 Views)
This looks like a good example too:
https://forums.ni.com/t5/Example-Code/IMAQ-Vision-ROI-Descriptor-Example/ta-p/3996147
(4,262 Views)
reading your message you want to capture from webcam imaenes your laptop, this program in Labview capture images from a USB camera to your application for further processing using the NI Vision module.
(4,167 Views)
If we draw ua perform extraction of the region of interest with a function for image processing that captures the last event of the RGB image (extract image coordinates and ROI)...
(4,163 Views)
