‎10-22-2015 09:21 PM
What is the recommended method for protecting the WebDAV login credentials within a vi? If there isn't a way, can a pharlap based labview RT be configured with a WebDAV only service account? I hate the thought of plastering my controller admin password into a vi.
xl600
‎10-23-2015 04:03 PM
Probably the best approach would be to password-protect the block diagram of the VI that contains the password information. Is this an option for you?
‎10-23-2015 04:57 PM
It's not my preferred option because that just creates another password to manage. I would also like to be able to change the admin password of the PXI controller without having to worry about altering code. A service account only capable of WebDav to/from specific paths on the controller would make a lot of sense here but I don't see any mention of how to set something like that up.
The permissions I see in the web interface don't appear to be granular enough to limit by protocol and there also doesn't seem to be file/path based permissions possible (Unless there's undocumented permission capabilities in LabView RT?).
‎10-26-2015 01:58 PM
I don't believe there is a way to do what you're describing in a Pharlap system. It might be doable in a Linux RT system, but in either case, it's not a build-in functionality to my knowledge. I suspect that password-protecting the VI is way to go on Pharlap.
