Web publishing the Front Panel developed on cFP2120?
I am developing a project on a cFP2120 controller with no host. So the front panel developed in the Real Time Software should be web published.
This project has been developed previously and to my surprise its running, as i had the understanding that when we deploy the RT code in the RT Target then Front panel of the code is not deployed in the RT Target, if that was true then how was it possible to Web publish the front panels.
I also checked the cFP 2120 Datasheet and it specifies that it has "Embedded Web and file servers with remote-panel user interface".
Please put in your thoughts on, If during deployment RT Front Panel is not downloaded on the RT Traget then how will cFP2120 web publish it?
and also kindly let me know if we can use the Event Structures in RT code? **just a complementary question**
(2,384 Views)
Please can someone give me some insight on the above question, I am waiting.
(2,374 Views)
