Web Services and HTTP headers
Hello all,
I am attempting to develop an application that streams data to a web page from a distributed system.  Right now, I am just trying to figure this all out, but I have hit a road block.  I have configured my VI of interest for streaming:
But, when I attempt to run this VI
I get the error −67305: Function not available for service VIs configured for headerless mode. Can anybody provide some guidance as to why this error might be thrown?
Cheers, m
(5,355 Views)
Accepted by topic author cirrusio
I found this forum post with someone who solved a similar issue with the same error code. http://forums.ni.com/t5/LabVIEW/Web-service-error-67305/td-p/2917312
Does this help you?
(5,323 Views)
Haha....Thanks, Riccardo.  I was going to close this as I found this to be the issue also.  Can anyone at NI explain why this is the case?  Is this supposed to be the way this operates?  Or should we file a CAR for this behavior?  If it is the expected behavior, then the checkbox "Buffered" ought to be dumped and the "Header" checkbox needs to set both of these values.
By the way, I am using LV 2014 and I still see this behavior.
Cheers, Matt
(5,313 Views)
I don't know about that, but I'll take a look into this further and see if a CAR should be filed.
(5,286 Views)
Hi Matt,
I've been doing a bit more research and there seems to be a CAR filed for this.
(5,174 Views)
OK.  Thanks.
(5,148 Views)
