Web Services Failed CAB Printer
I have a little problem with import WSDL from CAB.
IF I give web adresse http://ip_printer/services.wsdl
Labview say WSDL validation failed..
But if I give adresse through the browser I found this file....
<definitions xmlns="http://schemas.xmlsoap.org/wsdl/" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:tns="http://www.cab.de/WSSchema" name="cabPrinterWebService" targetNamespace="http://www.cab.de/WSSchema">
<documentation>This is a cab Printer Web Service.</documentation>
<types>
<xsd:schema elementFormDefault="qualified" targetNamespace="http://www.cab.de/WSSchema">
<xsd:element name="statusRequest" type="xsd:string"/>
<xsd:element name="statusResponse" type="xsd:string"/>
<xsd:element name="listOfFormatsRequest">
<xsd:complexType>
<xsd:sequence/>
</xsd:complexType>
</xsd:element>
<xsd:complexType name="format">
<xsd:sequence>
<xsd:element name="name" type="xsd:string"/>
<xsd:element name="description" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="listOfFormatsResponse">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="format" minOccurs="0" maxOccurs="unbounded" type="tns:format"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name="listOfObjectsRequest">
<xsd:complexType>
<xsd:sequence/>
</xsd:complexType>
</xsd:element>
<xsd:complexType name="objectType">
<xsd:sequence>
<xsd:element name="type" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="listOfObjectsResponse">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="fObject" minOccurs="0" maxOccurs="unbounded" type="tns:objectType"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name="listOfJobsRequest">
<xsd:complexType>
<xsd:sequence/>
</xsd:complexType>
</xsd:element>
<xsd:complexType name="job">
<xsd:sequence>
<xsd:element name="id" type="xsd:string"/>
<xsd:element name="date" type="xsd:date"/>
<xsd:element name="time" type="xsd:time"/>
<xsd:element name="status" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="listOfJobsResponse">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="job" minOccurs="0" maxOccurs="unbounded" type="tns:job"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name="loadFormatRequest" type="xsd:string"/>
<xsd:complexType name="loadFormat">
<xsd:sequence>
<xsd:element name="generic" type="xsd:string"/>
<xsd:element name="result" type="xsd:boolean"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="loadFormatResponse" type="tns:loadFormat"/>
<xsd:complexType name="objectTypePrint">
<xsd:sequence>
<xsd:element name="value" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="printFormat">
<xsd:sequence>
<xsd:element name="objects">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="fObject" minOccurs="0" maxOccurs="unbounded" type="tns:objectTypePrint"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name="jobID" type="xsd:string"/>
<xsd:element name="numbers" type="xsd:int"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="printFormatRequest" type="tns:printFormat"/>
<xsd:element name="printFormatResponse" type="tns:loadFormat"/>
<xsd:complexType name="faultType">
<xsd:sequence>
<xsd:element name="faultCode" type="xsd:string"/>
<xsd:element name="faultString" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="faultResponse" type="tns:faultType"/>
</xsd:schema>
</types>
<message name="getPrinterStatusRequest">
<part name="parameters" element="tns:statusRequest"/>
</message>
<message name="getPrinterStatusResponse">
<part name="parameters" element="tns:statusResponse"/>
</message>
<message name="getListOfFormatsRequest">
<part name="parameters" element="tns:listOfFormatsRequest"/>
</message>
<message name="getListOfFormatsResponse">
<part name="parameters" element="tns:listOfFormatsResponse"/>
</message>
<message name="getListOfObjectsRequest">
<part name="parameters" element="tns:listOfObjectsRequest"/>
</message>
<message name="getListOfObjectsResponse">
<part name="parameters" element="tns:listOfObjectsResponse"/>
</message>
<message name="getListOfJobsRequest">
<part name="parameters" element="tns:listOfJobsRequest"/>
</message>
<message name="getListOfJobsResponse">
<part name="parameters" element="tns:listOfJobsResponse"/>
</message>
<message name="loadFormatRequest">
<part name="parameters" element="tns:loadFormatRequest"/>
</message>
<message name="loadFormatResponse">
<part name="parameters" element="tns:loadFormatResponse"/>
</message>
<message name="printFormatRequest">
<part name="parameters" element="tns:printFormatRequest"/>
</message>
<message name="printFormatResponse">
<part name="parameters" element="tns:printFormatResponse"/>
</message>
<message name="faultResponse">
<part name="Error" element="tns:faultResponse"/>
</message>
<portType name="cabPrinterSOAP">
<operation name="getPrinterStatus">
<documentation>
Printer Status. Input Values: ESCs, ESCz, ESCi, ESCl, ESCa, ESCj, ESC?, Generic, Label Output Values: Generic: A generic Printer Status, Label: The loaded Label, Other: see Programming manual
</documentation>
<input message="tns:getPrinterStatusRequest"/>
<output message="tns:getPrinterStatusResponse"/>
<fault name="faultResponse" message="tns:faultResponse"/>
</operation>
<operation name="getlistOfFormats">
<documentation>
List of Formats. Input Value: void Output Value: The Lables stored on the primary card slot
</documentation>
<input message="tns:getListOfFormatsRequest"/>
<output message="tns:getListOfFormatsResponse"/>
</operation>
<operation name="getlistOfObjects">
<documentation>
List of Objects from the loaded Format. Input Value: void Output Value: The Objects from the loaded Format
</documentation>
<input message="tns:getListOfObjectsRequest"/>
<output message="tns:getListOfObjectsResponse"/>
</operation>
<operation name="getlistOfJobs">
<documentation>
List of last printer Jobs. Input Value: void Output Value: The last Printer Jobs
</documentation>
<input message="tns:getListOfJobsRequest"/>
<output message="tns:getListOfJobsResponse"/>
</operation>
<operation name="loadFormat">
<documentation>
Load Format. Input Value: The name from the Format Output Value: A processing status
</documentation>
<input message="tns:loadFormatRequest"/>
<output message="tns:loadFormatResponse"/>
</operation>
<operation name="printFormat">
<documentation>
Print Format. Input Values: The objects (name and value) from the label The JobID from the label The number of labels Output Value: A processing status
</documentation>
<input message="tns:printFormatRequest"/>
<output message="tns:printFormatResponse"/>
</operation>
</portType>
<binding name="cabSOAPBinding" type="tns:cabPrinterSOAP">
<soap:binding transport="http://schemas.xmlsoap.org/soap/http" style="document"/>
<soap:operation soapAction="status" style="document"/>
<input>
<soap:body use="literal"/>
</input>
<output>
</output>
<fault name="faultResponse">
<soap:fault name="faultResponse" use="literal"/>
</fault>
</operation>
<soap:operation soapAction="formatlist" style="document"/>
<input>
</input>
<output>
</output>
</fault>
</operation>
<soap:operation soapAction="objectlist" style="document"/>
<input>
</input>
<output>
</output>
</fault>
</operation>
<soap:operation soapAction="joblist" style="document"/>
<input>
</input>
<output>
</output>
</fault>
</operation>
<soap:operation soapAction="loadformat" style="document"/>
<input>
</input>
<output>
</output>
</fault>
</operation>
<soap:operation soapAction="printformat" style="document"/>
<input>
</input>
<output>
</output>
</fault>
</operation>
</binding>
<service name="cabPrinterWebService">
<documentation>A simple getStatus Web Service</documentation>
<port name="PrinterWebServiceSOAP" binding="tns:cabSOAPBinding">
<soap:address location="http://192.168.27.182/soap.cgi"/>
</port>
</service>
</definitions>
why it does not work in labview?
Best Regards,
Emmanuel
Message 1 of 9
(4,580 Views)
Hello Emmanuel,
please tell me first your current LabVIEW Version.
Best Regards
Simon
Message 2 of 9
(4,545 Views)
Hello Simon,
My Labview is edition 2013 SP2, but it's the same proble whith 2012.
Best Regards
Emmanuel
Message 3 of 9
(4,532 Views)
Hello Emmanuel
For some reason, sometimes LabVIEW fails to import Web Services WSDL because LabVIEW does not support importing multiple files from the Web Service, means the exported web service needs additional schemas outside the WSDL itself.
In order to make the import Web Service Tool to work correctly, there is a workaround. The Workaround now is to include these two files manually to the follow directories:
Main.VI» C:\Program Files......\LabVIEW 2013\vi.lib\Platform\WebService\Main Panel\Pages\Input WSDL
WebServiceUtil.dll»C:\Program Files.....\LabVIEW 2013\resource
Both files are in the .ZIP file in the attachments section.
The Main.vi file and the WebServiceUtil.dll that the computer already has should be backup.
Best Regards
Simon
Message 4 of 9
(4,522 Views)
I have the same problem since 2010 (see here) I tried your workaround but it
doesn't work for me, with soapUI it still works.
Greetings
Stefan
Message 5 of 9
(4,500 Views)
Hello Simon,
I have tested, but It's not ok.
For the main.vi is right?
Always the same error.
Best Regards
Emmanuel
Message 6 of 9
(4,497 Views)
Hello Emmanuel
Yes the path is right.
Here a link for the handling with WSDL and LabVIEW:
https://decibel.ni.com/content/docs/DOC-22722
Best Regards
Simon
Message 7 of 9
(4,449 Views)
 I have use the solution from Stefan.
Thanks to both of you
Emmanuel
My llb for other people....
Ps. If you make an update don't forget to post it
Message 8 of 9
(4,437 Views)
Hi Emmanuel,
can you please save your LLBs in LabVIEW 2012. At the moment they are in LV2013
and i didn't install it so far..
Stefan
Message 9 of 9
(4,433 Views)
