Web Server prompt
When I launch some exes, I get a prompt saying "The Web Server cannot start....."
Neither on the vi nor in the project have I enabled Web Service.
Anyone have an idea of why I get this prompt?
It is not a show stopper but it is annoying.
Brian
(2,873 Views)
The default LabVIEW built ini has the webserver enabled.
You have three options:
  1. Ignore the message (just like you do now)
  2. Disable the webserver by using a non-default INI with the following line:
    Webserver.enabled=false
  3. Change the webserver port for every executable by using a non-default INI with the following line:
    Webserver.port=#####
Good luck,
Ton
My LabVIEW Ideas
(2,858 Views)
Thanks Ton
Brian
(2,850 Views)
