11-08-2023 04:52 PM
Hello all,
I am using "basic function generator" in order to obtain a sin wave. I plot it in a Waveform Graph, but it only appears till second 1. I am attaching the file. Where is the problem?
Thanks in advance
11-08-2023 05:01 PM
a previous version if problem
11-08-2023 05:18 PM
The default "sampling info" is 1000 points. Once you create a diagram constant (or control) for it, you can change it.
Also
11-09-2023 01:41 AM
thanks for response!!
Coud I set sampling info i function of time of code execute? I mean, generating points in real time.
Also
Thanks in advance
11-09-2023 11:18 AM
Words such as "real time" have a very special meaning and I don't think that's what you mean (see also). can you explain exactly what you want to do?
Inputs to a function or subVI is just data and it does not care if it is from a diagram constant, from a control that can be changed by the user during a run, or from a result of a calculation.
A top-level while loop should typically not exceed the size of your monitor, else you are doing something wrong. Keep the code simple a modular and wrap relevant chunks into reusable subVIs.
Whenever you see a red coercion dot, it means that there is a mismatch in datatype and sometimes (not always!) it is better to fix it. For example, you could right-click...representation and pick something better for your constants. That sqrt and multiplication also needs to be done only once, so it belongs before the loop (Yes, the LabVIEW compiler is smart enough to treat it as such (constant folding, loop invariant code movement, etc) but code is easier to understand and debug if it shows the intent on the diagram.
Most inputs of functions have defaults and if you forget to wire them, that's what is being used. If you would set the "samples" input to 1, you would get an array with only one random point. The help explains that the default is 128 points. Of course you can also generate a random number with Gaussian distribution by using two dices and the Box Muller transform,
11-09-2023 12:17 PM
I will try to explain "real time" meaning on my best (I am not native). I would like to generate all points and plot them in the graph while time (X axis) is in progress (second 1, second 2, ... till stop code). In addition, the amplitude of the full wave is always de same, I mean, the first cicle of the wave has 230 of amplitude and the rest of the cycle have 230 of amplitude too. I would like to see first cicle with 228 of amplitude, second cicle with 231 (in function of random numbers generated)
11-09-2023 12:27 PM
What is a "cycle"? One wave (i.e. corresponding to 360 degrees)? You can adjust the sampling frequency, timing, # of points, etc. to get exactly that.
If only the amplitude ever changes, you can also generate one normalize wave once, then just multiply it with the current random number.
So you you want to generate and append to an ever-growing array of data (until you run out of memory) or just chart the data? How long is the final dataset? Do you want to plot it one point at a time or one cycle at a time?
11-09-2023 12:39 PM
I am attaching a photo. You coud see different amplitude values of the signal. I woud l like to plot generated random numbers in that way, because they all represent different levels of amplitude of the signal.
11-09-2023 12:56 PM
Sorry, I cannot see that. You have a repeating cycle of several harmonics of some fundamental period (outlined in green), but each repeat has very similar amplitude.
11-09-2023 01:10 PM
I mean this:
Labview generates the first random number (for example 243,1). Then, that value will be the amplitude of the funtion generator and it is shown in the graph, but the full sin signal has the same amplitude (243,1).
Labview generates the second random number (for example 600). Then, that value will be the amplitude of the funtion generator and it is shown in the graph, but the full sin signal has the same amplitude (600).
I would like to see 243,1 amplitude and, immediately, 600 value amplitude at once in the same graph of the sin signal at once.
