Waveform chart
But is there no way to remove this time indication since 1904?
Message 11 of 20
(1,991 Views)
of course there is!!!!
Message 12 of 20
(1,982 Views)
So how do I do this?
Message 13 of 20
(1,979 Views)
You need to give sufficient information instead of pictures!
We cannot tell what you have!
(My guess is that you should look at the properties of the chart, especially the x scale, and see if "ignore waveform timestamp is checked". We have no idea what kind if times you wired waveform contains.)
Message 14 of 20
(1,969 Views)
@altenbach, that´s the code.
Message 15 of 20
(1,926 Views)
@altenbach wrote:
..., maybe attach a simplified version of your VI (save for previous, 2020 or below).
It seems you did not read my post and attached in LabVIEW 2024 that few can open. (I have 2024 on a VM on a different computer and can possibly look at it later)
Message 16 of 20
(1,920 Views)
@altenbach, I would be grateful if you could see this for me! Thanks!
Message 17 of 20
(1,915 Views)
We're asking you to convert your VI to a previous version.  Most of us do not have LabVIEW 2024 so we cannot open it.
Use File > Save for previous Version... and select 2018.  It is an old version that everyone can edit.  😉
EDIT:  Also, no offense, but this is a very common issue that you can easily find the answer for if you do a little research. 🤓
Display Time and Date on a Graph or Chart in LabVIEW - NI
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 18 of 20
(1,913 Views)
The VI in version 18 of labview.
Message 19 of 20
(1,887 Views)
Hi Marcelo,
No, still in LV2024. (Exactly same filesize, just a slightly different filename…)
File->Save for previous, then attach the converted VI…
Message 20 of 20
(1,881 Views)
