Waveform chart digital display blinks zero....
  I am curious as to why the digital displays for a waveform chart sometimes blink zero?  It never shows up on the chart or in the data that is saved, so it does not really hurt anything.  However when someone asks why it happens I always just make up a good storySmiley Wink, so I am wondering what the real story is.  I have had it happen on many different machines and different versions of LabView so I imagine it happens to others as well.
Bryan
Message 1 of 16
(7,934 Views)
I've never noticed this...got a sample VI you can post?
Message 2 of 16
(7,927 Views)
This was reported to R&D (# 48O22J00) for further investigation.  The current work around is to not use the digital display and use just a numeric indicator.  I apologize for this issue.
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
Message 3 of 16
(7,913 Views)
Thanks for the info.  At least I am not as crazy as I thought I was.  Is there anyway to check the R&D number?
Message 4 of 16
(7,894 Views)
Future LabVIEW release notes will refer to that CAR ID Number for bugs that have been fixed.  Therefore, if R&D finds that it is a bug and fixes it, you will know by looking at the release notes.  Also, I believe R&D posts (or is going to start) to the discussion forums when the bug is fixed and released.
Daniel Eaton
Systems Engineering
Message 5 of 16
(7,873 Views)
The above CAR was closed as a duplicate of 36JB7QD8, so use this CAR nunber for future tracking purposes.
Roy
Message 6 of 16
(7,835 Views)
I am using Labview 8.5.1 and I still find that the waveform chart digital display blinks zero.
Message 7 of 16
(7,194 Views)
I am using LabVIEW 2013. The Stacked Waveform Chart, Digital Displays still blink "0.00".
Is there still no fix for this?
Message 8 of 16
(6,745 Views)
LabVIEW 2013 hasn't been released yet.
Do you mean LabVIEW 2012 service pack 1?
Message 9 of 16
(6,734 Views)
OK, LabVIEW 2012 SP1. But the DVDs are clearly labled 2013.Robot Happy
Message 10 of 16
(6,722 Views)
