Waterfall - Four Plots
Hello
I need to load a Waterfall graph with 4 plots at the same time. All the 4 plots will have the same number of elements for X, Y and Z, the only difference among them will be the magnitude of Y values. So, I can choose a different color for each one of the plots and represent all of them at same time.
Anybody has a VI example of this situation?
Dan07
(3,147 Views)
have you looked through the examples because there are a couple of 3D graph examples
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,138 Views)
Yes I did. But I didn't find a waterfall graph that accepts more than one plot.
The multiplot waterfall that I need should have 4 plots, all of them with the same number of elements for X, Y and Z, with a difference only on the magnitude of Y values.
Dan07
(3,118 Views)
