Want to convert the .DAQ file from MAX to a text file to be included with data runs for experiments.
I want to take the .DAQ file from the MAX program and convert it to a text file. From my understanding this file contains all the information for the channels and hardware that is currently set up on the system. I want to use this data as a file so that others can set up the experiment again in the future and this data would be helpful. Thanks in advance for any help in regard to this matter.
(2,843 Views)
There is discussion on this exchange on this exact matter. Do a search based on DAQ Configuration, and you should find the thread(s). Otherwise, sit back and wait, and I'm sure someone out there will be able to remember the thread offhand.
Good luck
(2,843 Views)
HAL;
I'm attaching a Labview example to this answer which does that with the properties of your virtual channels configuration in MAX. Other than that, there isn't any way, at this time, to convert the .daq file to a text file.
Hope this helps.
Filipe
(2,843 Views)
Thank you. This is exactly what I was looking for.
(2,843 Views)
