Want to contorl the Powersupply using labview
hi ,
I have the Time electronincs power supply , which has the Options of rs232 and GBIP . but i could no tfind any Driver file to interface with Labview .
Can you please guide me. My Requiremnt is , Just to control the Power supplyform labview .
I need to create any new driver or , can connect suing RS232 ?
i am the beginner of Labview . Please help me with some detailed information .
(2,561 Views)
Yes, you could create a single driver that would use either a serial or GPIB connection. At the main instrument driver network page (http://www.ni.com/downloads/instrument-drivers/), there is a section on driver development. One of the options is the instrument driver wizard that will create a series of typical VIs needed and you edit them to provide the actual commands for your instrument. The good news is that a power supply is one of the easiest to program.
(2,552 Views)
In addition to what Dennis mentioned, have your power supply's programmer's guide - it could be a separate document or contined withing the manual or user's guide - handy.  That is where you will find the necessary info to populate the driver shell with.
[edit]
As Dennis said, a power supply is one of the simplest device to program.  A great one to cut your teeth on!
[/edit]
Bill
CLD
(Mid-Level minion.)
(2,534 Views)
