WTH is an I32 precision?
@altenbach wrote:
All fractional decimal digits of an integer are zero. Why shouldn't you be able to display them if you want to?
 Now it looks a bit better 😉
Message 11 of 23
(1,507 Views)
@altenbach wrote:
All decimal digits of an integer are zero. Why shouldn't you be able to display them if you want to?
Sure, that makes sense. Especially for a user meeting your interface for the first time...
In the same vein, why shouldn't I be able to convert an integer into an absolute or relative time either? That's probably why I can.
Now I wonder why I can't give it a unit, but that's probably for another topic.
Message 12 of 23
(1,503 Views)
Because integer units seldom make sense.  Take 1Deg C for example it equals 273.15 (ish) Kelvin so it would be coerced without warning as an integer.  And we need not mention that units have prefixes.  Any guess what a Giga-unit Integer or Pico-Unit Integer would behave like?
"Should be" isn't "Is" -Jay
Message 13 of 23
(1,496 Views)
Well, SI formatting is allowed for an integer, so I guess it HAS TO make some sense...
Message 14 of 23
(1,482 Views)
@Darin.K wrote:
Wait. What?
Well, we already know that Altenbach doesn't really understand numbers.
___________________
Try to take over the world!
Message 15 of 23
(1,456 Views)
No, it does not need to make sense to you...In  the way you want it to make sense/  All I am saying is that is does make sense.  Just think like a computer!  They are very limited in the operattions they can preform
Message 16 of 23
(1,447 Views)
All right, so I want to be able to set the precision of I32 constants to arbitrary digits. How is that to think like a computer?
Oh, but wait, I can:
And BTW, the same constant reads like so in Absolute Time format:
and like this in relative time format:
My turn to play tricks!
Message 17 of 23
(1,442 Views)
@crossrulz wrote:
@for(imstuck) wrote:
For the same reason that %d stands for decimal when formatting a string with a number which has no possiblity of having digits after the decimal Smiley Very Happy
disclaimer: I'm sure there is a valid reason for this
Actually, there is a very valid reason.  Decimal simply means base 10.  Just the same way that Binary means base 2, Octal means base 8, and Hexadecimal (often shortened to Hex) is base 16.  All of these are dealing with integers.  The %d, %b, %o, and %x have been around at least since C got started.  They have nothing to do with the English name of decimal point.
Plus, look at your string<->Number conversions.  You will see a Decimal String to Number and Number to Decimal String.  Those are just using the %d convension.
Still you have decimals, so why not binals, hexidecimals and octals? Since you can have fractions of decimals you can ofc. have fractions of the other representations? Which leads to teh question: Why haven't there been a system based on the most divisable numer, the perfect number, why isn't there a 60base? Hexadecimal for real!
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 23
(1,437 Views)
I think the Mayans, or maybe the Babylonians, used base 60 for some of their astronomical calculations.  Most of us do not have enough fingers and toes to use base 60.
Lynn
Message 19 of 23
(1,417 Views)
Yet the Mayans were doing some pretty graphical things at the time...
Message 20 of 23
(1,363 Views)
